Video in Plex Web Media Manager
If the overlay with the videoplayer shows up, then the problem isn't in my javascript file(s). It can take a while before videos start playing.
argh, came here hoping for a Chrome solution. My Macbook died recently so I’m stuck with ChromeOS on the CR-48. I’d love to know if you get something going for it!
I’ve tried to get this to work with an embedded QuickTime player, but failed so far… :frowning:
This is an awesome lil plugin! Finally something to let me stream stuff to my PC at work so I when I have free time, can actually use the larger monitor instead of the iOS clients. Would love to have choice in the bitrate though. Maybe a separate script for each?
Has there been any update to include this functionality in the web manager? I tried it out back in February without any issues in Safari, but can't seem to get it to work now. Is there a reason Firefox 4 wouldn't be capable of playing the stream from PMS? I can't install Safari on my work laptop, and would love this option while on the road.
I’ve used it at my student home, where the server is located and it worked 2 days ago on my mac with safari. However, at home it doesn’t work anymore, it shows a pop-up: Unable to find video.
Streaming to my phone works so probably something changed in the code of PMS?
Yup, after upgrading my mini to 10.6.7 and 9.2.5 I get the same error in Safari on my MacBook: “Unable to find video info.” Any ideas?
I found my problem, apparently it doesn’t support password protected servers.
Edit: Is there a possibility to use a more flexible transcoded file to use in other browsers? I am not a coder, I don’t even know where to start, but this might be helpful/usable of is it only a demonstration: http://forums.plexapp.com/index.php/topic/22303-plex-transcode-api/page__view__findpost__p__144128
Yes, Firefox doesn't support H264 encoded "html5" video playback :huh:
Yes, but at this point many websites are still using it, so probably everyone will install the required plugin i guess. What about google chrome?
"html5" video doesn't work with plugins, more recent browsers support it out of the box. The only difference is in codec (and container) support.
Chrome has dropped support for H.264 encoded video...
Since you’re poking your head in here, Sander… =) Do you know how feasible it would be to update the bookmarklet to support having Secure Server Access enabled on the PMS? (It works if you’re accessing from inside your LAN, but not from externally.)
Well, it depends on what you call ‘plugin’ then, but Microsoft created an addon/plugin for chrome to support H264 encoded video on google chrome. Because Google dropped the support it should still work. ( http://arstechnica.com/microsoft/news/2011/02/microsoft-offers-h264-plugin-for-chrome-queries-google-on-webm.ars )
However, isn’t is possible to let the bookmarklet detect the browser and adapt the output to the corresponding needs? So for safari use the current solution and for IE use h264? I’m not sure if PMS can already transcode to webm, but you know that better than I do I guess.
You can get this to work using SSH. If you SSH into your computer and create a tunnel switching local ports with remote ports it will work. it kind of tricks the Plex Server into thinking you are local and not remote. I have it set up. it is really easy to do using the app SSHKeychain.
Mac Only.
I get the problem “Unable to find video info.” same as someone mentioned above.
Any ideas what this is?
Can you elaborate more on the tunnel for switching ports?
Is it possible to get with working while keeping authentication on? I love this! Only other thing that could make it better would be chrome/ff support.
Would this work with FireFox?
Firefox doesn't support h264 unfortunately.
Ive got the problem that it automatically plays audio #1, even if thats not my english preferred one. In PMS Ive set audio and subtitle to english, but in some TV shows the first audio is not english, but in safari its still playing the first one :confused: Any ideas about this?
I’m pretty sure the client requesting the transcode (which is what is happening with Safari here) normally specifies which audio and/or subtitle stream to use if there are multiple. I doubt the bookmarklet is intelligent enough to be able to do that, so (I’m assuming here) the PMS just uses the first/default one if it’s not specified.
There’s probably a way you could modify the bookmarklet to request a different stream (and maybe just have multiple versions of the bookmarklet for the different stream numbers/positions?), but I don’t know what sort of syntax is used in the requests to the PMS, so I really don’t know how it would need to be modified.
