I have noticed that playing back a movie on the iPad using the Plex app the video quality is by far less good than if I connect to the directory where the movie is stored and I use a movie player to play it.
Why Plex is downgrading the movie resolution?
What are your playback Quality settings?
If you turn off “Use Recommended Settings”, you can then manually select a quality and see which you like best.
Thanks for the fast reply, but where is this quality setting?
Found!
I put it to maximum (I am streaming videos in my LAN).
Seems better, before was set to 2 Mbps 720. I was mislead by the option description that said Internet Streaming so I thought that the speed was the limit when streaming outside the LAN (remote connection).
Thanks again
In the upper right corner, tab the 3 horizontal bars (where you sign in.
You’ll see:
Sync
Friends
Settings
Tap Settings and the Settings popup will appear.
