Hey,
Just installed 1.8.0 embedded EGL on an Intel NUC and videos which use AAC-LC codec doesn’t output audio?
Have I goofed up the settings?
Cheers,
TheBlackMini
Audio settings in OpenPHT:
Output 7.1
Passthrough enabled with all options ticked.
Output from MediaInfo on the file:
Format : Matroska
Format version : Version 4 / Version 2
Writing application : FastLE v3.0.0 - AVS
Writing library : libx264 + libebml + libmatroska + libfastrar
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3.1
Codec ID : V_MPEG4/ISO/AVC
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : A_AAC
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 spf)
Compression mode : Lossy
