video restart always from beginning
I have a plex running on a ASUSTOR NAS. It works perfectly. but if I stop a video, the next time I make that start, it starts from beginning and not from were I left.
Some times ago I had a Plex running on a PC and this fuction was working well.
Any idea on the reason? Any solution?
Depending on your client app…
There are two ‘play buttons’. If you have left the episode in progress, the top button starts from the beginning, the second button (with the dots) is either a ‘Play Version’ button or a ‘resume from Button’ or both. You can also start playback from continue watching (unless you have more than 3 items in progress and your item happens to be #4 - then you’ll never see it).
