Video streaming plugin for wireless IP cameras
Hi!
I just read the thread back and earlier on you said:
How do you select that **mpeg** stream? Is there a direct link to that?
This particular model unfortunately does not support MPEG. Another model I was considering does. I didn’t think MJPEG would be an issue.
There’s maybe one solution to get an image in Plex, but it’s far from perfect. It involves building something with Flash. A tiny Flash application that grabs the output of snapshot.cgi (http://192.168.0.43:6060/snapshot.cgi) and refreshes it every second. Then put the this Flash app in an HTML page and put both files on a server somewhere (preferably within your own home network). Write a Site Config for this Flash app, place it in ~/Library/Application Support/Plex Media Server/Site Configurations and create a .strm file with the plex:// webkit url.
I have some Sitecom WL-404 IP cameras with URL similar to this http://xxxx.yyyy.zzzz:8080/img/video.mjpeg
What should I do to add those streams to my Plex? As far as I understood I have to create a file with a certain name and extension that contains the URL. Could you give more details, like file location, file name, exact content to be written? Thanks in adavance
ok, this is the solution for your problem:
  1. make .strm file with this link: http://ipcam-url:port/videostream.asf?user=username&pwd=password
  2. replace camurl, port, username and password with your information
  3. add folder with that file to PMS
  4. thats it :wink:
How would one go about creating said .strm file? I’ve read a lot of documentation on the Plex Dev site and Google and it’s just not clicking for me.
Edit: Found this link: “http://dev.plexapp.com/tools/strmtool.php” which created the steam file. I took the file and dumped it into my existing Movies folder, it added to Plex but says “Error while opening file.” Is there a log file which I can look at to see what is going on?
My password has a space in it so I tried both the plus sign and %20 but neither worked. Any other ideas?
Edit 1: Went back and re-read the earlier posts and saw that we shouldn’t be using the webkit if we have access to the steam, so I updated the .strm file with jus the URL and tada - it worked.
Cheers
I have a similar issue. I have a Foscam FI8910w, which can use the same URL as pointed out by brnistra. However when I create the .strm file with my direct URL, I don't get any error messages, but the "Retrieving" progress bar just doesn't progress. If I view plex in a web browser, the stream just spins, but never displays. Any thoughts? If I open the URL I put in the .strm file in a browser, it starts downloading an infinitely long file.
Hi, I am curious if anyone has gotten this to work. I get cannot get it to work with my y-cam. I get the following error: "Cannot load M3U8:404 not found".
Thanks.
UPDATE: followed photovor and removed the webkit but still does not work and just spins.
Thanks.
"Cannot load M3U8:404 not found" is an error seen in Plex/Web. .strm files are only somewhat supported in the desktop clients of Plex (strm support is a leftover from the XBMC code).
