video vs. photo handling of art and thumb
Guys,
I noticed that photo plugins stretch their thumbs across the bottom-right area whereas prefix the same plugin with /video yields a nicely fitted icon...
Where can this be fixed? I pasted what I mean below. First image as video plugin, second as photos plugin.
Thanks!
JP
![post-2548-0-72143500-1405709372.png|690x388](upload://qGdmyD8oXTTRxxrHoZ1kDAB0CbS.png)
![post-2548-0-87510900-1405709505.png|690x388](upload://ws6WvVDXZwZl23APQvQDiS7tEzf.png)
what is the name of the plugin you are using?
also the MediaStream skin is not longer supported and is probably broken in many ways. Does this happen with the default Plex Skin?
Hi BigWheel! I am revisiting my old WebGalleryOfArt which used to be listed. I had upgaded to v2 and have still a couple of glitches to sort out...
Since when is there a new skin? Isn’t bundled with PHT updates? Not sure where this MediaStream skin comment comes from…
Since when is there a new skin? Isn't bundled with PHT updates? Not sure where this MediaStream skin comment comes from..
this skin is called just called "Plex"  it looks like below it as introduced in PHT 1.0  the Mediastream skin stopped being updated at the same time. the media stream skin stopped being in the installer since 1.0.9 ( if you had it before 1.0.9 it would still be there since auto updates won't remove it.
https://blog.plex.tv/2013/11/23/plex-home-theater-1-0-released/
Oh man!!! All sorted. I completely missed all this as my MacMini has been getting old running Plex since 2008 or so… I installed Chrome on the machine which let me discover the proper downloads. Now I am set and the code renders as ecpected.
Great stuff!!!
Thanks again
I installed all from scratch
