I tried a video with vorbis audio and it required transcoding. I’ve been looking around and some people claim that the raspberry pi can decode vorbis in hardware. Is that true?
Is there anything I have to do to enable direct play of vorbis?
RPi should be able to do Ogg Vorbis and VP6/VP8/Theora, but only accelerated in the VideoCore, will check with our resident coding gurus if this is possible for RasPlex.
I’ll check the video/audio combination (I am not at home right now). But I am pretty sure it was h264 with vorbis audio on an mkv container.
I’ll try your suggestions, thanks.
well, this is embarrassing…
The settings did work, and vorbis is now using direct play.
But! the sample I provided has 10 bit video… so transcoding is needed anyway
Thanks for the help!
EDIT: confirmed with another video, direct play works!
