WARN - [CERT] TLS connection from x came in with unrecognized plex.direct SNI name; using installed
Server Version#: 1.41.3.9314
Player Version#: 4.141.0
I am using the plexinc/pms-docker and I am having odd issues streaming files suddenly, it buffers all the time.
Docker is running on Oracle Linux 9 in a Windows Hyper-V VM (planning to move it eventually). Everything is behind Traefik with internal IP addresses in HTTPS with a certificate resolver and a custom root certificate configured through step-ca and traefik-foward-auth. The port 32400 is exposed.
While looking at the logs I noticed lots of warning of this type. I was wondering how to fix that (or how I could fix the streaming buffering errors, locally, it seems to work at lower bandwidth so anything 4K does not work).
