Web Client selection behavior [BUG]
Web client Version 4.8.1
When selecting a library on the left pane it resets to the top. the right pain shows the correct information but now your not shown which library was selected.
This is a current limitation. We are looking to prevent this in the future.
Edit: Got it. Problem happens when you have to scroll down to get to desired library.
The selected library is displayed in the top left corner of the right pane, above the sort options.
In the list of libraries, the selected library has a yellow bar to the left. It is also has a lighter grey background than the other libraries.
Do you see something different? Am I misunderstanding something?
