[WEBHOOK] Plex is no longer triggering definted webhook
Server Version#: 1.31.2.6810
Player Version#: N/A
I have a webhook setup for trakt.tv, and it stopped working back in January. I just assumed that maybe my trakt subscription ended or something. However I have now checked everything and all is in order.
After investigation there seems to be no attempt by the server to send a webhook. I would assume it would show up in the logs (which are enabled and showing entries), however there is no attempt nor any errors. I have also turned verbose on and again nothing.
I have double checked the setup from this page: https://trakt.tv/settings/scrobblers
  • The webhook is correct
  • Push notifications are enabled
  • Webhooks are enabled
I have updated to the latest version and restarted the server and nothing. Is there any way to confirm that plex is definitely at least attempting to send the webhook so I can isolate the issue.
send it here and see what comes through
Brilliant thank you.
Well I don’t know what is going on as now the trakt one is working…big shrug. All I did was add the additional testing webhook. Well that’s 2 months of annoyance solved somehow.
