Webhooks no longer properly fire media.stop when media is finished playing
At some point in the last year the Webhook media.stop event no longer fires when media is finished playing, it fires when the user manually exits the Post-Play screen, meaning the media.stop event wont fire at all without manual intervention or configuring the server with a paused-too-long timeout (and waiting 10 minutes isn’t really a good workaround here).
Is this new behavior intended? Having the media.stop event fire when media stops playing was so much more useful for integrating with home automation like lights, and this pretty much doesn’t work anymore. I’ve tested this behavior using the nVidia SHIELD and the Apple TV4K for playback, and they both exhibit this problem.
bumping this. was this change to how the media.stop Webhook event fires intentional? or is this at least a bug being tracked?
It has been filed as a bug.
Can you confirm that this is still an issue?
I noticed a week or two ago that this seems to have been fixed, and I just double checked right now and can confirm: The Media.Stop event correctly fires when the media has finished playing and the player is left at the Post-Play screen.
Thank you!
