Webhooks
Server Version 1.20.5.3583
Anyone else that got an issue with webhooks right after the last update?
My webhook works with media.play.stop/etc but not with media.new…for some reason it just stopped working.
When i check the logs it says it accessed the url but when you check the logs in the “web server” there was never an access from the webhook.
Tips pls!
Cmon someone help me out :slight_smile:
I’m also seeing the same issue. I have my webhook endpoint on debugg mode and am only seeing:
  • media.scrobble
  • media.play
  • media.stop
  • media.resume
  • media.pause
  • device.new
However no library.new webhooks :confused: very disappointing.
Yepp, same here :frowning:
Same here, would be nice if advertised features was working.
I have exactly the same issue. Push notifications are on.
Did nobody figure this out?
I am having the same behavior.
I want to trigger on library.new
I solved my issue and if i remember it right it was a command for the sql to update to the current date that was the problem.
Do a quick search and i think you will find it.
Seeing this issue as well, can’t seem to find the command though for the sql call. Any help with direction or a link?
