Webkit Cookies Location
As i understand it, Webkit cannot use or access the cookies that the main plex plugin code generates or stores. Presumably the HTTPCookies file under the \Plex Media Server\Plug-in Support\Data\com.plexapp.plugins.[plugin_name] folder is the file containing the cookies for the main plex plugin code.
If the above is true, where does PMS store the Webkit cookies? Is there a file somewhere on the PMS server that i can look at to examine the raw cookies? I'm having some issues with my site configurations throwing errors and i think it might be related to cached cookies. (Just a guess)
Thanks!
@mattrk did you ever figure this out? I’m having a problem where I need to find cookies too.
No, i didn’t. However, webkit has been deprecated for a while. So i wouldn’t bother messing with it.
