Webtool, Subtitle Manager (Development)
Think it's a double plex folder..
I don't live in QNAP land but i think:
PlexMediaServer\Library\Plug-ins\DevTools.bundle-master
that should be the path..?
Remove the -master from dir name
yeah i missed that :(
ok here are the prefs:
But now your tool works as it should:
YAY :D
PS:
LOL
Can you please try to remove one subtitle? Since removing them dosn't work for Tommy.
And Tommy, can you please try to remove one and then check the logfile? If you have downloaded the fresh, out-of-the-oven on page 4. :)
Ah it doesn't delete...
error log
At work now.
Will do tonight
So i tried to dele the local file by selecting it then pressing delete selected and...
it deleted all Plex subs but the local files for the whole season!
error log
WHAT?!
How the hell did that happen?
Unless any other for that episode is selected, it can't remove it. The delete.php file goes through the selections only, and each episode is devided into their own form section. So one delete can't find the selectionboxes of another episode.
That is very strange and scary. The logfile you posted only shows removal of one srt, 4x01 - fallout.eng.srt. Not anything else..
But i can see that it's not showing that it found anything else.
Are the files "physically" removed? The agent-srts i mean.
Yup they are all gone. Nothing left on the nas. And the local srt it was meant to delete is still there
I can't understand it. The last error file you posted, was that the complete? It was so small.. And it only showed one delete..
It didnt remove anything else but the subtitles? I hope it didn't ruin too much..
Edit:
I've been trying to in some way reproduce the problem but i've failed to do so.
I have tried:
- Removing a local subtitle from a show: Worked as designed, subtitle was removed, page reloaded and it was gone from the list. Nothing else removed.
- Removing a agent subtitle from a show: Worked as designed, as above.
- Checking more subtitles on different seasons: Worked as designed.  Only the subtitle for the season that had the delete selected button was removed. Nothing else.
-  Tried to delete selected with nothing selected and nothing happened as designed.
Not sure how to fix this at the moment. I'll go through the code again and see if there is something missing.
I can try another season
I don't care much for the subs :)
It did it again! Doesn't delete my plex sub and when I try to delete the local sub delete all subs from the season from plex subs leaving all the locals ones intact.
Maybe you forgot an update in the delete.php?
@Dagalufh:
Where's the log-file supposed to end up?
@Ismelda:
Where did you find it?
@Dagalufh:
Ismelda's logfile shows, that you are using the hardcoded and invalid path from the settings file when deleting, and not the one received from my Plug-In, or ?
Unable to find 'C:/users/Your Windows Account Name/AppData/Local/Plex Media Server/Media/Localhost/b/3450b4640cd87ff8e189f77ce85a9502504246c.bundle/Contents/Subtitles/fr//com.plexapp.agents.opensubtitles_0bc01a0f8166e7eee6800ec272ae1408c94823a5.srt' on disk.
Also note the double // right before com.plexapp.agent........
/T
And regarding the // caracters, you might wanna check out this:
$fullPath = join(DIRECTORY_SEPARATOR, array($directoryPath, $fileName));
/T
"it" being?
"it" being?
The logfile.....Can't find it  :wacko:
It is in plexusm folder as long you are using the latest version: plexusm_v0.4.3 (plexusmerror.log)
Sniff....not here  :(
Did you do anything in the settings file to enable it?
I did set the $Debug to true
/T
@dane22
"Unable to find 'C:/users/Your Windows Account Name/AppData/Local/Plex Media Server/Media/Localhost/b/3450b4640cd87ff8e189f77ce85a9502504246c.bundle/Contents/Subtitles/fr//com.plexapp.agents.opensubtitles_0bc01a0f8166e7eee6800ec272ae1408c94823a5.srt' on disk."
that is not from her latest? Can't find it there...
Do the webbuser have write permissions in it's own directory? plexusm directory?
I'll look into //, do you think it have an impact?
@ismelda
Can you toss over the latest logfile you have? That has everything from the deletion?
I can't understand how that can be happening so need some logs...
Perhaps it's something in delete.php. But there has to be something in index.php aswell... Subtitles checkboxes data that is being sent even when it shouldn't or something..
Like always I plugged it and expected it to work, and it did this time.
There is a log file as soon you start plexusm so the only reason you wouldn't have one is:
1. wrong server
2. not using v0.4.3
@ dagalufh:
all, my files (from my nas) have an url with "//com.plexapp..." from your log.
Here is the log I got from deleting all my season 3 subs from plex while trying to delete the local one from the 1st episode.
I do believe the "//' is the culprit.
