Either here, or in a DM
Followup for others who stumble upon this. Looks like there is a PMS bug that has broken the View State Copy function. A bug report has been logged with the Plex team.
Can confirm that the latest Plex update has fixed the issue with view state copy.
I’m having an issue with the Find Media tool where scanning any library seems to stall near the end - the status just gets stuck.
Here are some examples - any well known issues/workarounds?
Status: Processing
Info: Scanning Library
Items: Processing item 600 of 645
Status: Processing
Items: Processing item 3780 of 3782
Status: Processing
Items: Processing item 3380 of 3384
Switch WebTool-NG to Silly log level, and restart.
Then reproduce, and upload both WebTools-NG logs as well as Plex Media Server logs in a zip
Sorry for the delayed reply - I’ve been cleaning out a lot of old library files and updating others. After a day it the Find Media tool seems to be working correctly now. Thanks for your response.
Hi dane22. I installed the WebTools-NG on Windows to connect to a PMS in the local home network, and I want to export only the movies that have a certain genre, or that are in a certain collection.
I did not find any option in the GUI to do that.
Is that possible using WebTools-NG?
Andy
WebTools-NG does not support filters while exporting, so your option is to export all into a CSV file, and afterwards delete the unwanted entries
Thanks for the quick answer!
Hi, I’ve searched but not had much luck. What do the options in Global Settings / PMS Settings do?
Are they controlling the timeouts for only the Webtools connection? Or are they setting that timeout value for the Plex Server for all clients?
It’s the timeout for Webtools-NG, while communicating with your server
Thanks. Was looking for a way to stop Plex timing out while an HD spins up. Back to the search! ![]()
Looks like the error affecting View State Sync is back. WebTools-NG v1.2.1.f962812 and PMS Version 1.40.0.7775
Yep, I’m facing the same issue ![]()
Where can I find out more about the WT beta?
I downloaded and installed the non-beta version… I noticed it is from 2022… I assume beta is current? is there a feature list, fix list?
There’s currently no beta running, sorry
Is this a dead project?
I hope not ![]()
Just been darn busy last year, so sadly no spare time
Are yow the author, or one of them?
