when seeing a video in plexconnect and someone calling me on skype which is installed and turned on on the same computer, plexconnect quits the video and in the left side down of the screen it writes untitled/untitled 1 i don't remember and have the music without artwork icon. airplay pr something like that isn't enable at all. photos at post #7
Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software):3 5.3
The DNS server set on the ATV (found under the ATV settings > general > network > DNS):192.168.1.150
The device and operating system (including version number) that PlexConnect is installed on:imac os x 10.8.4
The local IP address of the device that PlexConnect is installed on:192.168.1.150
The device and operating system (including version number) that the Plex media server (PMS) is installed on:IMAC OS x 10.8.4
The Plex media server (PMS) version number you are running (**do not put 'latest'**):0.9.7.28.33
The local IP address of the device that the Plex media server (PMS) is installed on:192.168.1.150
The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any testing branch e.g. the Elan/PlexInc one. monday 00:00 8.7.2013
The content of your 'Settings.cfg' file (if you do not have this file you are running an old version, please update):
[PlexConnect]
port_pms = 32400
enable_plexgdm = True
ip_dnsmaster = 8.8.8.8
ip_webserver = 0.0.0.0
loglevel = Normal
enable_dnsserver = True
ip_pms = 192.168.178.10
port_webserver = 80
A detailed description of the issue (the clearer you can make this the better):up up :)
Hmm i did not realise they did not have this option on the OSX version.
I have asked in the Skype forums for an answer as it is bad behaviour by the Skype application (a act that they have recognised on the windows version and given you an option to turn it off).
