I started putting data over on Google drive a couple weeks ago. It has been working great until tonight. I just got the Google Drive ban. I have update library automatically turned on but update periodically turned off. When I have been adding content, it doesn’t ever show up within plex unless I click on the library and click update. This is most likely what caused the issue tonight. Does anyone have any ideas? or what do you do? Thanks!
The ones that I’ve seen having success using GDrive, and avoid bans, use ocmal for mounting and not rclone
I have been using rclone encryption so I am assuming that would not be an option anymore. Any other ideas?
You can still use it, just mount with ocaml then point your rclone crypt drive to that mount.
eg let you mount with oclam to /mnt/acd ( where all content is in encrypted folder ) then open rclone.conf and change the crypt part to point there eg /mnt/acd/encrypted
Personally no, this is why I’m still using ACD for plex streaming and GDrive as a backup until if and when the rclone mount issues get worked out with GDrive
@Ajki said:
@ml3000 said:
I have been using rclone encryption so I am assuming that would not be an option anymore. Any other ideas?You can still use it, just mount with ocaml then point your rclone crypt drive to that mount.
This sounds interesting but I am sorry. Could you go into more detail here? I am a sysadmin just not a linux one so i struggle through it. Have you had this work?
