I've got the PlexConnect daemon up and running. It auto-starts PlexConnect when I reboot the computer. Currently, I'm using the launchctl load/unload commands to manually stop or start PlexConnect when I need to make changes to or update the PlexConnect files:
Yeah, I guess you could. But then it wouldn't run with sudo rights... unless you pop up a window and ask for permission.
We might add something like this in the future, but honestly, it doesn't help to much and also not all our users (very different setups...)- so I concentrate more on subtitles and stuff.
You could have a look at a couple of scripts I created, one of them is an applescript application, so double-click (or single click if you drag it into the Dock) will run it.
