@ Shr00m76 In addition to checking your naming, check your agent settings. Just checked that movie and all the main actors show up.
Since Plex takes its data from an online database, and since this online database is open for editing and submission, why not enter or edit the movie that has no cast/wrong cast in the database, instead of āfixingā only your own? In this way the cast will be available for every user with the same movieā¦
Response to OPā¦
Probably Neverā¦
bump, I would also like this feature to be added
Desperately need this feature. Maybe even on an episode level I would like to be able to add actors.
Still not added. I canāt even think of a reason why this canāt be done
Me neither! I really hope the developers will add this feature in a near future.
@zpaolo11x said:
Since Plex takes its data from an online database, and since this online database is open for editing and submission, why not enter or edit the movie that has no cast/wrong cast in the database, instead of āfixingā only your own? In this way the cast will be available for every user with the same movieā¦"
The problem with that is I have some movies that it pulls through the databases used by Plex (IMDB) and it still does not add the actors into Plex, though they are listed on the page at IMDB. For example Conan the Barbarian (1982). I even changed the options for where its to pull the data from IMDB to Plex movie and back, removed the metadata and more.
Yup I want it too!
I also want to be able to select if i agree with the plex match, it has this habit of mismatching relatively obscure movies, it then just renames them and POOOFFF its disappearedā¦
The only way you can then find the miss matched movie is to hit the home button and look under newly added. Ive just added a movie call āim still waiting for youā and it matched it to ālovers Laneā a totally different movie, there needs to be a check box option for you to agree or disagree with in accurate matches.
Any news about this!!??
Same **** different year. Plex doesnāt give a flying crap about the core functions of this product.
Just add it under COLLECTION and then you could search using that feature on the filter menu, works perfectly. I just did it for Tom Hanks which didnāt show up in a search on my Nvidia Shield search on plex.
