Where is the download for an SD card to go into a RaspberryPi? I have the Pi3.
I can only find downloads for Windows, Mac, Playstation Etc. I found the instructions for creating the Image on an SD Card using 7zip and Win32DiskImager, but I cannot locate the file to download.
Go to http://www.rasplex.com/get-started/rasplex-installers.html and download the installer for the operating system you will use to make the card. The installer will ask the location of the card and what version pi you have and will put the image on the card for you. There is no reason to do it manually as all the hard work is done for you.
There is no download for plex server on raspberrypi, you will have to build a package using arm7 or armv7 images from plex.tv to run on your Rpi 2 or 3 … OR, you can visit these guys that have doen it already and download a ready made image. http://www.iiot.co.za/Image_Raspberry_Pi_Plex_Media_Server
You are in the wrong section of the forums, go to to the Linux section and look for ‘I have PMS running on a Raspberry Pi’.
This section is for the Rasplex client only.
Regards
