When using Plex in docker container most videos will stop playing half way and just show loading circle.
If the video is stopped and I attempt to resume it the video will keep loading and never play, but if left alone for long enough with no user connected the problem will go away for long enough to watch one episode.
This issue only started after the latest update and does not happen if the plex server is run on my windows computer.
Please see logs and let me know if there is any other info needed to fix this issue.
Looks like the most recent playback in your logs stopped around the 6-7 minute mark, correct? The transcoder appears to run very slowly from that point. Are you sure that you aren’t filling the disk where the transcoder temp is stored?
You say this doesn’t happen if you run it on your windows computer. Are you running this in docker on windows (highly discouraged because Window’s docker implementation isn’t complete enough to work) or are you running this on a different computer or dual booting?
Same thing happening to me since update… wtf…
