Why does plex direct play 720p but transcode 1080p down to 720p
The settings are all default on the xbox one app.
I use plexwatch and i’ve been through every xbox item in the list and they all transcode for 1080p but direct play 720p
Is this a limitation of plex on xbox?
What is your xbone resolution set to?
The following link shows what will and will not DIRECT PLAY
https://support.plex.tv/hc/en-us/articles/203824396-What-media-formats-are-supported-
Check Your settings, it needs to be set to original for it to NOT transcode. Like this…
Also, you can check on the webpage for your server under “Status” → “Now Playing” to see what is being transcoded.. here I am transcoding both Audio and Video (because xbox does not support 4K Video or DTS)
