@trudge said:
@Elijah_Baley said:
@trudge said:
@Elijah_Baley said:
So I do consider DrivePool, properly configured, to be at least a reasonable local backup solution.
Until your house burns down, of your server gets stolen, or you spill a jug of water on it, or your filesystem corrupts, or malware encrypts it
Redundancy is not backup.
Which is exactly why I said “local backup” and why I also said “DrivePool is not a fully functional backup because there is no provision for detaching a drive and storing it in a different location and, unless you turn on 3X or more duplication, there is no way to be sure of recovering from two drive failures at the same time.”
It is not a local backup, it is disk redundancy. A local backup implies you can survive a server localised disaster. I’ve just given you multiple examples (and far from a complete list) of server localised disasters your data cannot survive.
If you setup is sufficient for you then that is fine, but don’t redefine existing terms by calling it something it isn’t - it just confused people who don’t know any better.
Backup as used here from the Merriam-Webster dictionary
3: a copy of computer data (as a file or the contents of a hard drive); also : the act or an instance of making a backup
Redundancy: the closest definition I can find to what is meant here from the same source:
3: serving as a duplicate for preventing failure of an entire system (as a spacecraft) upon failure of a single component
So it seems that both words are similar in meaning and use but only “backup” refers to computer data directly. You may define them differently and even use them differently BUT under the definition of “backup” a local copy IS a backup. It is not a 100% safe backup but it is a backup. Planing for the disasters you mentioned is, in many cases, just not needed as what you mention are so farfetched or so serious that planing for them and spending money on them is absurd for many people.
In the first case (like theft or spilling water on my server) those are so unlikely as to be absurd to consider. My drives are external to my computer so the likelihood of two drives corrupting or failing at the same time for any reason is small and my server is not going to get malware except by an extreme fluke.
Backup is NOT being perfectly safe it is protecting your stuff to the degree you are willing to live with. DrivePool, for me, provides that protection so I consider it a local backup. It could even be safer as it could use the cloud for the duplicated but my upload is so slow that it would take a year or better to get everything uploaded.
You can define “backup” however you want but I choose to use the term as it is defined in common English so DrivePool is a local backup solution for me.
You are also in error as to what “local backup” means as “local backup” just means the ability to recover from failures using local resources not the ability to recover from things that destroy what is local.
I have the ability to recover locally from any reasonable failure that can happen so I have a reasonably good local backup. If anything worse happens, and it is possible just unlikely, I will simply cope with it. As I said before it is only entertainment and not worthy of over thinking it or over spending on it.
