Why is Gong Li called Wu Yigong in Plex!
Gong Li, the famous Chinese/Singaporean actress :
Doesn’t appear in the cast of any movie she is staring in in Plex !!
(the case in all clients I tried : web, mac os, apple TV os)
Instead Wu Yigong :
appears in the cast of all of these movies …, with below picture :
What gives ? :flushed:
Is it some kind of a strange joke from a developer who hardcoded that in plex code ? :confused:
It needs to be fixed !! :laughing:
Note : I just did a quick test to see if for some strange reasons this would happen only with libraries in French, but no, it happens with library in English as well :
(and “Song Lian” is indeed Gong Li’s character name in this movie)
will now add a Wu Yihong movie to see what it does.
Adding Wu Yihong movies with fake files (directing and acting), he appears “normally”(except for replacing Gong Li as actor of course) , either as actor or director :
So nobody cares ? :grinning_face_with_smiling_eyes:
Of course all the metadata regarding Gong Li is “correct” in TMDB or IMDB, how could this happen without “hard coding it” in Plex code ?
You’re right, I just refreshed the meta data on Raise the Red Lantern and Gong Li vanished and was replaced by Wu Yigong. I’m not actually sure what sources the new agent uses to get the info, but why would Plex hard code this, it’s more likely to be downstream from Plex somewhere and will be fixed in a day or two.
I highly doubt that any central db would have this mixed up regarding Gong Li, not the case in the Movie db or IMDb for sure, at least.
So I would not be surprised if it is some kind of strange joke by a dev ! :slight_smile:
(like a fan pissed off that she took the Singaporean nationality or something)
Or maybe a really strange bug ?
And it is the case for all the movies she appears in, I have most of them (I admit being a fan :blush:) : the case for all of them !
So a central DB error would require the error being present on all these movies.
I’ve forwarded this issue to the developers. Apparently it is caused by some weird identification duplication in one of our data sources.
I’m told it is not an easy fix, so it might take a while to sort it out.
Thanks ! And now that I know it, not so much of an issue (just have to click on Wu Yigong to access Gong Li’s movies), but can understand it is a tricky one (would be interesting to know if there are other similar cases).
Same problem.
Same problem
Thought I’d give this post a bump.
Can someone from Plex look into this issue? Please?
Thanks!
This issue still has not been fixed.
This issue is still there, and there are more and more issues…
Someone maybe taking the micky out of Plex after I found Wu Yigong has replaced renowned actress Gong Li in Memoirs of a Geisha, Miami Vice and Mulan.
From Miami Vice (2006) XML
Server Version#:
“take a while” means months, still no ETA?
This is also happening to Damon Wayans, it is pulling his son Daman Wayans Jr.
Another month passed
Please, Plex, fix this.
One of the most beautiful actresses…
1
…replaced with an old geezer in B&W
2
Actress Gong Li mislabeled in meta data as “Wu Yigong” also picture looks like a Chinese man in glasses .
Server Version#:4.69.0
Good grief, this is not sabotage by Plex.
Actor portraits are completely screwed up everywhere for me, this isn’t a conspiracy.
