Just ran a database optimisation to see if this fixes these search speeds.
Get this in the log files
! Optimizing database. Starting by capturing all sessions.
! Apr 12, 2016 09:06:08:229 [11228] DEBUG - Captured session 0.
! Apr 12, 2016 09:06:08:229 [11228] DEBUG - Captured session 1.
! Apr 12, 2016 09:06:08:229 [11228] DEBUG - Captured session 2.
! Apr 12, 2016 09:06:08:229 [11228] DEBUG - Captured session 3.
! Apr 12, 2016 09:06:08:229 [11228] DEBUG - Captured session 4.
! Apr 12, 2016 09:06:08:230 [11228] DEBUG - Captured session 5.
! Apr 12, 2016 09:06:08:230 [11228] DEBUG - Captured session 6.
! Apr 12, 2016 09:06:08:230 [11228] DEBUG - Captured session 7.
! Apr 12, 2016 09:06:08:230 [11228] DEBUG - Captured session 8.
! Apr 12, 2016 09:06:08:230 [11228] DEBUG - Captured session 9.
! Apr 12, 2016 09:06:08:230 [11228] DEBUG - Captured session 10.
! Apr 12, 2016 09:06:08:230 [11228] DEBUG - Captured session 11.
! Apr 12, 2016 09:06:08:230 [11228] DEBUG - Captured session 12.
! Apr 12, 2016 09:06:08:230 [11228] DEBUG - Captured session 13.
! Apr 12, 2016 09:06:08:230 [11228] DEBUG - Captured session 14.
! Apr 12, 2016 09:06:08:231 [11228] DEBUG - Captured session 15.
! Apr 12, 2016 09:06:08:231 [11228] DEBUG - Captured session 16.
! Apr 12, 2016 09:06:08:231 [11228] DEBUG - Captured session 17.
! Apr 12, 2016 09:06:08:231 [11228] DEBUG - Captured session 18.
! Apr 12, 2016 09:06:08:231 [11228] DEBUG - Captured session 19.
! Apr 12, 2016 09:06:08:231 [11228] DEBUG - Database optimization: Rebuilding full text search tables.
! Apr 12, 2016 09:06:17:492 [11228] WARN - Held transaction for too long (Library\FullTextSearch.cpp:16): 9.250859 seconds
! Apr 12, 2016 09:06:17:767 [12168] DEBUG - Request: [192.168.0.3:53051] GET /library/recentlyAdded?X-Plex-Container-Start=0&X-Plex-Container-Size=10&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx (6 live)
! Apr 12, 2016 09:06:17:767 [12168] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
! Apr 12, 2016 09:06:17:767 [12168] DEBUG - Auth: Came in with a super-token, authorization succeeded.
! Apr 12, 2016 09:06:20:781 [11228] WARN - Held transaction for too long (Library\FullTextSearch.cpp:26): 2.995219 seconds
! Apr 12, 2016 09:06:24:662 [11228] WARN - Held transaction for too long (Library\FullTextSearch.cpp:35): 3.822024 seconds
! Apr 12, 2016 09:06:26:607 [11228] WARN - Held transaction for too long (Library\FullTextSearch.cpp:45): 1.887612 seconds
! Apr 12, 2016 09:06:26:630 [11228] DEBUG - Database optimization: starting.
! Apr 12, 2016 09:06:37:794 [13964] DEBUG - Request: [192.168.0.3:53105] GET /status/sessions?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx (6 live)
! Apr 12, 2016 09:06:37:795 [13964] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
! Apr 12, 2016 09:06:37:795 [13964] DEBUG - Auth: Came in with a super-token, authorization succeeded.
! Apr 12, 2016 09:06:57:843 [9796] DEBUG - Request: [192.168.0.3:53132] GET /library/recentlyAdded?X-Plex-Container-Start=0&X-Plex-Container-Size=10&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx (7 live)
! Apr 12, 2016 09:06:57:843 [9796] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
! Apr 12, 2016 09:06:57:844 [9796] DEBUG - Auth: Came in with a super-token, authorization succeeded.
! Apr 12, 2016 09:07:13:208 [11228] DEBUG - Database optimization: complete.
It is these Held transation for too long warnings that have me worried - is it just giving up on rebuilding the full text search tables?
There are also these lines after the database optimisation that have me worried.
! Apr 12, 2016 09:07:13:221 [11228] INFO - SQLITE3:07E42835, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
! Apr 12, 2016 09:07:13:229 [11228] INFO - SQLITE3:07E42835, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
! Apr 12, 2016 09:07:13:230 [11228] INFO - SQLITE3:07E42835, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
! Apr 12, 2016 09:07:13:247 [11228] INFO - SQLITE3:07E42835, 17, statement aborts at 58: [select * from metadata_items limit 1] database schema has changed
I have attached the full server log - all that has happened in this log file is server start, and 3-4 optimisation actions.
When database optimisation used to finish we were alerted in plex web werent we?
