Guys what about this issue ?
12-06 00:20:16.769 i: Fetching [method:GET] https://192.168.100.200:32400/video/:/transcode/universal/decision?audioBoost=100&autoAdjustQuality=0&directPlay=1&directStream=1&fastSeek=1&hasMDE=1&location=lan&mediaBufferSize=29952&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F156&protocol=*&session=a925e8cf91178404-com-plexapp-android&subtitleSize=100&X-Plex-Client-Identifier=a925e8cf91178404-com-plexapp-android&X-Plex-Client-Profile-Extra=add-limitation(scope%3DvideoCodec%26scopeName%3Dh264%26type%3DupperBound%26name%3Dvideo.level%26value%3D51)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.width%26value%3D3840%26replace%3Dtrue)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.height%26value%3D2160%26replace%3Dtrue)%2Badd-limitation(scope%3DvideoAudioCodec%26scopeName%3Daac%26type%3DupperBound%26name%3Daudio.channels%26value%3D6%26replace%3Dtrue)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dmp3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Deac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Ddca)%2Badd-transcode-target(type%3DsubtitleProfile%26context%3Dstreaming%26protocol%3Dhttp%26container%3Dmkv%26subtitleCodec%3Dsrt)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dmpeg2video)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3Dhevc%26type%3DMatch%26name%3Dvideo.profile%26list%3Dmain%7Cmain%2010)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dhevc)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DNotMatch%26name%3Dvideo.anamorphic%26value%3D999%26replace%3Dtrue)&X-Plex-Device=SHIELD%20Android%20TV&X-Plex-Platform=Android&X-Plex-Platform-Version=6.0&X-Plex-Product=Plex%20for%20Android&X-Plex-Supported-Commands=abort&X-Plex-Version=5.2.0.477&X-Plex-Token=...YRsD
12-06 00:20:16.773 i: [RefreshRateBehaviour] Ignoring sticky intent
12-06 00:20:16.773 i: [HdmiUnplugBehaviour] Ignoring sticky intent
12-06 00:20:16.818 i: [MediaDecisionEngine] Server was happy with client's original decision
12-06 00:20:16.818 i: [MediaDecisionEngine] Decision: CanPlay: true CanDirectPlay: true CanDirectStreamVideo: false CanDirectStreamAudio: true CanDirectPlaySubtitle: false CanTranscodeSubtitle: false
12-06 00:20:16.822 i: [video] Decision made, transcode: false
12-06 00:20:16.823 i: [TranscodeSession] Media choice updated
12-06 00:20:16.823 i: [VideoOverlay] Updating...
12-06 00:20:16.824 i: [video] Starting Playback for: Пока не Ñыграл в Ñщик
12-06 00:20:16.824 i: [Exo1VideoPlayer] Using ExtractorRendererBuilder with container type mkv.
12-06 00:20:16.825 i: [RefreshRateBehaviour] Checking refresh rate
12-06 00:20:16.828 i: [RefreshRateBehaviour] Target refresh rate: 23.976
12-06 00:20:16.828 i: [RefreshRateBehaviour] Refresh rates available: 23.976025, 24.0, 25.0, 29.97003, 30.0, 50.0, 59.94006, 60.0
12-06 00:20:16.829 i: [RefreshRateBehaviour] Current refresh rate: 60.0
12-06 00:20:16.831 i: [RefreshRateBehaviour] Best refresh rate: 23.976025 (1920x1080)
12-06 00:20:16.831 i: [RefreshRateBehaviour] Performing refresh rate switch, 23.976025 (id: 0)
12-06 00:20:16.839 i: [RefreshRateBehaviour] Detected display changed (0).
12-06 00:20:18.350 i: [AudioCapabilities] Capabilties changed (AudioCapabilities[maxChannelCount=2, supportedEncodings=[2]])
12-06 00:20:18.350 i: [HdmiUnplugBehaviour] Detected HDMI unplugged event.
12-06 00:20:18.399 i: [AudioCapabilities] Capabilties changed (AudioCapabilities[maxChannelCount=8, supportedEncodings=[2, 4, 5, 6, 7, 8, 14]])
12-06 00:20:18.400 i: [RefreshRateBehaviour] Detected HDMI plugged event.
12-06 00:20:18.400 i: [RefreshRateBehaviour] Building renderers...
12-06 00:20:18.402 i: [ExoVideoPlayer] Renderers received
12-06 00:20:18.402 i: [ExoVideoPlayer] Seeking to 0ms
12-06 00:20:18.406 i: [pms] /127.0.0.1:43239 - GET /proxy
12-06 00:20:18.406 i: [Proxy] Request received: https://192.168.100.200:32400/library/parts/155/1463001229/file.mkv?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=29952&X-Plex-Client-Identifier=a925e8cf91178404-com-plexapp-android&X-Plex-Supported-Commands=abort&X-Plex-Token=...YRsD
12-06 00:20:18.434 i: [Exo1VideoPlayer] Player state changed: 2, Restarting: true
12-06 00:20:18.460 i: [Proxy] Response: 200
12-06 00:20:18.566 i: [pms] /127.0.0.1:51537 - GET /proxy
12-06 00:20:18.567 i: [Proxy] Request received: https://192.168.100.200:32400/library/parts/155/1463001229/file.mkv?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=29952&X-Plex-Client-Identifier=a925e8cf91178404-com-plexapp-android&X-Plex-Supported-Commands=abort&X-Plex-Token=...YRsD
12-06 00:20:18.599 i: [Exo1VideoPlayer] Bandwidth sample, Elapsed: 102, Bytes: 5669, Bitrate: 444627
12-06 00:20:18.640 i: [Proxy] Response: 206
12-06 00:20:18.669 w: [pms] Socket exception detected
12-06 00:20:18.671 w: [pms] Client closed the channel
12-06 00:20:18.775 i: [pms] /127.0.0.1:34980 - GET /proxy
12-06 00:20:18.776 i: [Proxy] Request received: https://192.168.100.200:32400/library/parts/155/1463001229/file.mkv?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=29952&X-Plex-Client-Identifier=a925e8cf91178404-com-plexapp-android&X-Plex-Supported-Commands=abort&X-Plex-Token=...YRsD
12-06 00:20:18.796 i: [Proxy] Response: 206
12-06 00:20:18.803 i: [pms] /127.0.0.1:48019 - GET /proxy
12-06 00:20:18.803 i: [Proxy] Request received: https://192.168.100.200:32400/library/parts/155/1463001229/file.mkv?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=29952&X-Plex-Client-Identifier=a925e8cf91178404-com-plexapp-android&X-Plex-Supported-Commands=abort&X-Plex-Token=...YRsD
12-06 00:20:18.812 i: [Exo1VideoPlayer] Bandwidth sample, Elapsed: 132, Bytes: 196032, Bitrate: 11880727
12-06 00:20:18.812 i: [Exo1VideoPlayer] Player state changed: 3, Restarting: true
12-06 00:20:18.862 i: [Proxy] Response: 206
12-06 00:20:18.904 w: [pms] Socket exception detected
12-06 00:20:18.906 w: [pms] Client closed the channel
12-06 00:20:18.975 i: [pms] /127.0.0.1:43106 - GET /proxy
12-06 00:20:18.976 i: [Exo1VideoPlayer] Bandwidth sample, Elapsed: 107, Bytes: 9266, Bitrate: 11880727
12-06 00:20:18.978 i: [Proxy] Request received: https://192.168.100.200:32400/library/parts/155/1463001229/file.mkv?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=29952&X-Plex-Client-Identifier=a925e8cf91178404-com-plexapp-android&X-Plex-Supported-Commands=abort&X-Plex-Token=...YRsD
12-06 00:20:19.045 i: [Proxy] Response: 206
12-06 00:20:19.079 w: [pms] Socket exception detected
12-06 00:20:19.080 w: [pms] Client closed the channel
12-06 00:20:19.185 i: [Exo1VideoPlayer] Bandwidth sample, Elapsed: 101, Bytes: 0, Bitrate: 11880727
12-06 00:20:19.251 w: [pms] Socket exception detected
12-06 00:20:19.252 w: [pms] Client closed the channel
12-06 00:20:20.155 i: [pms] /127.0.0.1:48450 - GET /proxy
12-06 00:20:20.155 i: [Proxy] Request received: https://192.168.100.200:32400/library/parts/155/1463001229/file.mkv?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=29952&X-Plex-Client-Identifier=a925e8cf91178404-com-plexapp-android&X-Plex-Supported-Commands=abort&X-Plex-Token=...YRsD
12-06 00:20:20.210 i: [Proxy] Response: 206
12-06 00:20:20.360 i: [Exo1VideoPlayer] Bandwidth sample, Elapsed: 101, Bytes: 0, Bitrate: 11880727
12-06 00:20:20.418 w: [pms] Socket exception detected
12-06 00:20:20.420 w: [pms] Client closed the channel
12-06 00:20:22.322 i: [pms] /127.0.0.1:52786 - GET /proxy
12-06 00:20:22.322 i: [Proxy] Request received: https://192.168.100.200:32400/library/parts/155/1463001229/file.mkv?autoAdjustQuality=0&hasMDE=1&location=lan&mediaBufferSize=29952&X-Plex-Client-Identifier=a925e8cf91178404-com-plexapp-android&X-Plex-Supported-Commands=abort&X-Plex-Token=...YRsD
12-06 00:20:22.379 i: [Proxy] Response: 206
12-06 00:20:22.524 i: [Exo1VideoPlayer] Bandwidth sample, Elapsed: 101, Bytes: 0, Bitrate: 11880727
12-06 00:20:22.525 e: [Exo1VideoPlayer] Player error detected
12-06 00:20:22.525 e: An exception occurred: com.google.android.exoplayer.j: com.google.android.exoplayer.ai: Lacing only supported in SimpleBlocks.
12-06 00:20:22.525 e: Stacktrace: com.google.android.exoplayer.j: com.google.android.exoplayer.ai: Lacing only supported in SimpleBlocks.
at com.google.android.exoplayer.am.a(SourceFile:262)
at com.google.android.exoplayer.am.d(SourceFile:144)
at com.google.android.exoplayer.p.j(SourceFile:439)
at com.google.android.exoplayer.p.handleMessage(SourceFile:211)
at android.os.Handler.dispatchMessage(Handler.java:100)
at android.os.Looper.loop(Looper.java:148)
at android.os.HandlerThread.run(HandlerThread.java:61)
at com.google.android.exoplayer.g.y.run(SourceFile:40)
Caused by: com.google.android.exoplayer.ai: Lacing only supported in SimpleBlocks.
at com.google.android.exoplayer.d.g.g.a(SourceFile:782)
at com.google.android.exoplayer.d.g.h.a(SourceFile:1322)
at com.google.android.exoplayer.d.g.a.a(SourceFile:123)
at com.google.android.exoplayer.d.g.g.a(SourceFile:346)
at com.google.android.exoplayer.d.j.h(SourceFile:835)
at com.google.android.exoplayer.f.x.run(SourceFile:222)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:423)
at java.util.concurrent.FutureTask.run(FutureTask.java:237)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1113)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:588)
at java.lang.Thread.run(Thread.java:818)
12-06 00:20:22.547 i: [video] Direct play failed, attempting to transcode
12-06 00:20:22.549 i: [MediaDecisionEngine] Starting media decision for: Пока не Ñыграл в Ñщик (part index 0)
12-06 00:20:22.550 i: [Exo1VideoPlayer] Player state changed: 1, Restarting: true
12-06 00:20:22.551 i: [MediaDecisionEngine] Transcode server selected: PowerServer
12-06 00:20:22.552 i: [MediaDecisionEngine] Analyzing media: 1920x1080 23996kbps (Container: mkv, Video: vc1, Audio: ac3)
12-06 00:20:22.552 i: [MediaDecisionEngine] Unable to direct play; Direct Play was attempted but failed, fallen back to transcoding
12-06 00:20:22.553 i: [MediaDecisionEngine] Original quality selected, skipping resolution/bitrate check
12-06 00:20:22.554 i: [MediaDecisionEngine] Unable to play; server unable to transcode video
12-06 00:20:22.554 i: [video] User maximum h264 profile determined: 51
12-06 00:20:22.555 i: [video] Device recommended h264 profile determined: 51
12-06 00:20:22.556 i: [VideoUtils] MediaCodec found (OMX.Nvidia.mpeg2v.decode) for video/mpeg2
12-06 00:20:22.557 i: [VideoUtils] MediaCodec found (OMX.Nvidia.h265.decode) for video/hevc
12-06 00:20:22.563 i: Fetching [method:GET] https://192.168.100.200:32400/video/:/transcode/universal/decision?audioBoost=100&autoAdjustQuality=0&directPlay=0&directStream=1&fastSeek=1&hasMDE=1&location=lan&mediaBufferSize=29952&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F156&protocol=*&session=a925e8cf91178404-com-plexapp-android&subtitleSize=100&X-Plex-Client-Identifier=a925e8cf91178404-com-plexapp-android&X-Plex-Client-Profile-Extra=add-limitation(scope%3DvideoCodec%26scopeName%3Dh264%26type%3DupperBound%26name%3Dvideo.level%26value%3D51)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.width%26value%3D3840%26replace%3Dtrue)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DupperBound%26name%3Dvideo.height%26value%3D2160%26replace%3Dtrue)%2Badd-limitation(scope%3DvideoAudioCodec%26scopeName%3Daac%26type%3DupperBound%26name%3Daudio.channels%26value%3D6%26replace%3Dtrue)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dmp3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Dac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Deac3)%2Badd-transcode-target-audio-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26audioCodec%3Ddca)%2Badd-transcode-target(type%3DsubtitleProfile%26context%3Dstreaming%26protocol%3Dhttp%26container%3Dmkv%26subtitleCodec%3Dsrt)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dmpeg2video)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3Dhevc%26type%3DMatch%26name%3Dvideo.profile%26list%3Dmain%7Cmain%2010)%2Bappend-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhls%26videoCodec%3Dhevc)%2Badd-limitation(scope%3DvideoCodec%26scopeName%3D*%26type%3DNotMatch%26name%3Dvideo.anamorphic%26value%3D999%26replace%3Dtrue)&X-Plex-Device=SHIELD%20Android%20TV&X-Plex-Platform=Android&X-Plex-Platform-Version=6.0&X-Plex-Product=Plex%20for%20Android&X-Plex-Supported-Commands=abort&X-Plex-Version=5.2.0.477&X-Plex-Token=...YRsD
12-06 00:20:22.586 w: [pms] Socket exception detected
12-06 00:20:22.588 w: [pms] Client closed the channel
12-06 00:20:22.620 i: [MediaDecisionEngine] Server was happy with client's original decision
12-06 00:20:22.622 i: [MediaDecisionEngine] Decision: CanPlay: false CanDirectPlay: false CanDirectStreamVideo: false CanDirectStreamAudio: false CanDirectPlaySubtitle: false CanTranscodeSubtitle: false Transcode Reason: Direct Play was attempted but failed, fallen back to transcoding
12-06 00:20:22.649 i: [video] Item cannot be played.
12-06 00:20:22.650 e: [Video Player] A non-recoverable error occurred while attempting to play: /library/metadata/156.
12-06 00:20:22.650 e: [Video Player] Сервер Ñлишком Ñлаб Ð´Ð»Ñ ÐºÐ¾Ð½Ñ†ÐµÑ€Ñ‚Ð°Ñ†Ð¸Ð¸ видео.
12-06 00:20:22.651 i: [Video Player] Showing playback error dialog.
12-06 00:20:26.585 i: [pms] /192.168.100.30:52438 - GET /logging
i have several files in my collection which dont play on my nvidia shield tv
Android Plex Player 5.2.0.477
Plex Media Server 1.3.1.3085
Kodi 17 Beta6 play all this files without any problem !
