Plex for Android 5.10.2 4k h265 ok
plex beta 5.11.0.466 The 4k is broken
Nothing works with this version, all the files are transcode
Have you updated to latest pms?
yes , 1.7.2.3878
Can you provide a log from the client?
Private messages
Can you provide me the XML for that file? I’m guessing it’s a 10-bit or HDR source, which PMS cannot transcode. The Shield should be able to direct play the file so I’ll check your logs to see why it’s not.
8bits or 10bits or hdr h265 4k, plex in version 5.11, impossible to read a 4k. It tries to transcode the vidéo,
version 5.10.3 works , direct play ok -> h265 4k , 8bits ,10bits,hdr (June 6)
I do not speak English, not easy to explain
4K represents a single element of the video file: resolution.
Post the full XML of the file.
@piou44 said:
8bits or 10bits or hdr h265 4k, plex in version 5.11, impossible to read a 4k. It tries to transcode the vidéo,version 5.10.3 works , direct play ok → h265 4k , 8bits ,10bits,hdr (June 6)
H265 is only supported in Direct Play. Any other little thing that prevents direct play will result in a transcode. This is why we need to see the entire output of what PMS thinks is in the file.
You can post in your preferred language. Google translate can help me figure it out.
I can confirm the same problem. Play any 4K videos crashes Plex.
I don’t have problems with 4K videos playback
Can you create a 30s-1min sample file? Test if this also crashes the app, then upload this to a sharing site then PM me a link.
I rolled back to 5.10 version since noticed the problem. Even the 2160p remux is playing smoothly now
@MovieFan.Plex said:
@koo_sg said:
I can confirm the same problem. Play any 4K videos crashes Plex.Can you create a 30s-1min sample file? Test if this also crashes the app, then upload this to a sharing site then PM me a link.
Just updated to latest version 6.0.1, no problem with 4K videos
At least try and hide the piracy, jesus.
That naming convention is just awful.
A few posts have poped up in regards to this.
There was another on reddit I seen last night also
For full transparency, Nads PM’d me asking me to remove my comment r.e. his naming convention. I promptly declined to do so.
Thanks for the transparency post
I wouldn’t worry about it. I see no issue with it seeing as you can’t rip 4K movies yet as AACS 2.0 hasn’t been cracked. The sooner it gets done and integrated into MakeMKV the better for everybody. At least your choice of reference material is excellent. Can’t get over how good the Planet Earth II theme is, Hanz Zimmer nailed it.
