I have some 4K content and trying to transcode and my i5 cannot handle it. Pegs at 100% and the video buffers.
Looking around there are lots of old rackmount servers with dual Xeon processors for under $250. Will Plex use all cores of both processors? Realistically this should be a better option than one i5, yes?
FYI, QuickSync does require an active Plex pass to work. If you do not have a lifetime pass, keep in mind you’ll have to keep renewing it until Plex (maybe) turns it into a mainstream feature.
Give it a try with your current processor before buying anything else.
I am not optimistic. So far, reports from Windows users tell us that one transcoding stream will only use one cpu. The second cpu is only used when transcoding 2 streams at once (i.e. concurrent transcoded playbacks on 2 different clients).
i see some talk here about intel quicksync vs quadro p2000. Is there any more documentation regarding hardware transcoding with plex? everything I find seems to be very old, outdated, or just plain wrong. I would love to see a benchmark done on transcoding with various GPUs, and what the limitations of each one is.
Last I checked, it wasn’t. As long as you install the correct drivers and cuda, hw encode worked, but not hw decode.
I figured out that it was due to a missed build flag (for enabling cuvid) when compiling plex’s ffmpeg fork. I brought it to the devs’ attention but they said nvidia wasn’t officially supported so they wouldn’t fix it
