Background (skip if you don’t care):
Over the years I’ve purchased and converted A LOT of media to digital format and set it up to be streamed on my Plex server. I’ve slowly sent out invites to share my media with my closest friends and family members and watched the CPU usage and logs to try and determine if and when my hardware started capping me. I’m afraid to say that I’ve finally reached that point.
The main issue is transcodes. For the life of me, I cannot fathom why Plex doesn’t have an option to disable transcoding. I get that it’s an impressive feature and they’re very proud of it, but they have to understand it’s not for everyone. I’ve been tempted to purchase the PlexPass so I can set up a Tautulli agent to stop transcodes, but after having purchased the Plex app on too many devices already, I don’t really feel being muscled into a subscription service is a great way to address the lack of significant features.
I used to tell people they had to have a Roku , a strong internet connection, and must set their app to Force Direct Play. I required a Roku specifically because it natively supports my media formats, and because I use a Roku, I knew how to walk them through their settings/screens (every device’s Plex app is different for some god awful reason). Well, managing users is like herding cats. Even when you get them set up right, they always manage to find a way to screw everything up. They’ll reset their devices, purchase new ones, or purchase wrong ones, and I’m tired of spending time on it.
Current Setup:
Just an old gaming PC running Windows 10 I converted into my Plex Server. I’ve got 10 TBs of usable storage, 16 GB of RAM, a GTX 980, and a i5 CPU clocked at about 3.2Ghz. Home internet connection is 1Gbps u/d, hardlined. Case is an Antec 900 for lots of airflow.
My media is all 1080p, and I generally aim between 10-12 mbps for average video bitrate (variable). I code x264 into a mkv container. Audio tracks are ripped between 1500-2000 kbps DTS. The main reason I rip this way is I don’t own a 4k TV or anything fancier than a 5.1 surround sound system, and when I started this, I read those were pretty much the standards.
What I need:
I want to just build a server that can handle a bunch of simultaneous transcodes. My max concurrent transcodes so far is 6, and it had some stuttering. I’d like to prepare for at least 10 simultaneous transcodes. I’m just not sure what I need. I’m looking at building 2-CPU setup via a dual-cpu mobo, but I’m not sure if that’s good enough. Is there much of a transcoding performance difference between i5’s and i7’s (or i3’s for that matter)? Is Intel better than AMD for transcoding purposes? As far as I can tell, I don’t really need much for RAM, and the GPU isn’t even used at all. Do I need to into more of a rack system to get the performance boost I’m looking for? My HDDs are set up in a storage pool with redundancy, so I doubt I/O would ever be an issue.
