I have recently bought a WinTV Dual HD tuner to use with Plex.
My OS is Elementary OS (Ubuntu 16.04).
I was having some difficulty getting it to pickup HD channels but have solved it by booting with the patched 4.4 kernel that is installed when following the Hauppauge Linux guide: http://www.hauppauge.com/pages/support/support_linux.html
However I can’t get it to appear as 2 tuners. In the logs I see mentions of merging 2 tuners to one whereas before the kernel switch it was saying merging 1 tuner. I am thinking that since I setup the DVR device before using the patched kernel, it is persisting some settings.
I have deleted the device several times but it still comes back as a single tuner. Any ideas? I don’t really want to install Plex from scratch again and I’m not even sure that is going to fix it.
Yeah I get that it will only appear as a single device. However it explicitly says on that device ‘1 tuner’ and I can only play one channel concurrently.
Upgrading the kernel? From the documentation only 4.4 is supported for my Ubuntu version. Will this not work with a dual tuner? I need to test but I think outside of Plex it is seen as 2 tuners.
I’ve tested using the plex docker container (same version of plex I am running normally) and the device is showing as having 2 tuners. Also 2 channels can play concurrently.
This is making me think the device is not fully removed when I select to delete the device within the plex UI. Are there any files that may need deleting in order to fully remove all traces of the device?
I can obviously switch to using a docker container but I don’t really want to transfer all of my settings, etc…
