Hope someone can help on what I thought would be a pretty simple issue.
Setup: Plex Server setup on an Win7 w/i7-4770k, and two rasplex clients. All wired feeds. One has both the MPG2 and VC-1 codecs purchase and installed, the other one does not.
I have a bunch of Audio CD's ripped to a WMA lossless format. If I try to play, I get an error "Unable to Play Media" and "Play Back Failed" in big red bands. Both units fail to play WMA
I can stream it to my Win7 computers just fine, but not the Rasplex. I'm sure there is a codec issue, but I don't see where you can add a WMA codec.
A quick search shows WMA not supported as of about 2012. IS this still the case?
Would prefer to get the WMA working if it’s just something easy like a checkbox in the preferences. I was considering FLAC going forward, but finding and converting all those WMA files sounds like a PITA…
Would prefer to get the WMA working if it's just something easy like a checkbox in the preferences. I was considering FLAC going forward, but finding and converting all those WMA files sounds like a PITA...
It might just be a matter of finding a tool which can convert all your files in batch mode, while preserving the metadata.
I know the old trusty Winamp and MediaMonkey can do this.
If you're not on Windows anymore, there may be others.
Gets a little more interesting....I can play from the Plex web page on my computer were Plex is running (not surprised by that), and from my Ipad just fine. I cannot play from the 2 Rasplex's or from an android phone. Not sure what to make of this...but i don't think its a DRM or a codec issue anymore.
The error message on the Rasplex says to "make sure the file exists and that the necessary drive is mounted". Could the code be trying to mount this to play like a virtual CD?
I ripped these years ago into a WHSV1 environment and transfered them to a WHS 2011 box. have streamed them to all sorts of things over the years.
I'm trying to figure out how to paste files to this site, I cant seem to get it working in either chrome or IE...I'd expect you would like some log files in addition to the WMA file?
Can you PM me a link to a file on something like Dropbox, Onedrive, etc.
Was there any resolution to this problem? I have the same issue on WMC: Plex Web plays WMA lossless not problem, WMC gives the red bar “unable to locate media” error
0.7.1 plays .wma files but there is a pause every 9-12 seconds. It always pauses at the 12 second mark, then about every 9 seconds. Is there a 0.7.2 pre release I could try?
