Wont play more than one episode
I recently started to experience when I choose a tv show and hit play or shuffle where it previously would continue to play now it only plays one episode and stops.I stream from my computer to my Xbox one using the Plex app on my Xbox and the server running from my PC on the same network. I recently installed Plex on a fresh install of Windows 10. I was curious if I’m just forgetting a setting or what could cause this. I don’t recall ever having to change anything for this to happen, pretty sure it has always done this automatically.
The auto-play is handled by the player. Check your xbox for a autoplay feature.
But I may be wrong.
Thanks for the reply, I’m not sure what happened or why but it’s resolved itself. I’m not sure why they say it’s a upcoming feature it’s always played automatically for me. I choose a show and press play or shuffle and it’ll continue to play by itself. It always has since I used the XBox 360. It started doing it by itself so who knows. :smiley:
Well, both were posted back in 2017 but I thought it might be a starting point for you.
But I’m glad it works for you now.
