Doesn’t play the movie I select.
did you click on the movie you wanted, and still plays wrong one? I have had before were it was miss tagged, were the picture and info was for one movie but was linked with another move all together. I would check the movie that does play instead of the one you want if its listed twice or not. Most likely its a tagging issue.
Tried that and didn’t change. It’s like everything is out of sync. Maybe I will try removing the file from plex and then reconnecting it.??
Call up the Plex XML info of the movie and post it here.
Side note: are you familiar with this?
https://support.plex.tv/hc/en-us/categories/200028098-Media-Preparation
