Server Version#: Version 1.41.3.9276 - Ubuntu Server 22.04 - X86 - Docker
Player Version#: Version 4.141.0 (Web), but from any client
Setup:
Home Server: Running Plex in Docker (host mode) on a 5G connection behind CGNAT - no publicly reachable IP so therefore I have a VPS. Home server advertises 192.168.1.0/24 subnet range to rest of tailscale network.
VPS: Fixed public IP, acting as an Nginx reverse proxy using Tailscale to route traffic to the home server. - Ubuntu Server 24.04 - Nginx Proxy Manager in docker.
The Problem: Plex shows the Tailscale IP (e.g., 100.x.x.x) as the “remote IP” for clients instead of the real client IP, despite correct forwarding of the X-Forwarded-For header from Nginx.
Plex logs(verbose) show XFF: client ip (the real ip)and X-Real-IP as well.
Reverse proxy config for Plex
location / {
proxy_pass https://192.168.1.12:32400/;
# Override headers for Plex
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header Host $host;
proxy_set_header X-Forwarded-Host $host;
proxy_set_header X-Forwarded-Proto $scheme;
# Pass only the first IP in X-Forwarded-For
set_real_ip_from 100.64.0.0/10; #Tailscale range
real_ip_recursive on;
real_ip_header X-Forwarded-For;
Remote access is disabled in Plex server settings and public url(s) are entered in Custom server access URLs - https://plex.domain.com:443,http://plex.domain.com:80,https://192.168.1.12:32400.
Domain is registered on Cloudflare, but CF for plex is used as DNS only, not Proxied.
Everything else, other than client IP being shown as VPS tailscale ip (100.93.57.14) is working flawlessly. Every client I tested with can reach my server and use the content but also shows exact same IP.
I have seen this topic mentioned around the forums but nobody really offers a solution/explanation.
Can anyone advise what am I doing wrong here? I can provide logs (both plex and nginx).
Sample Log below:
Blockquote
MessageX-Forwarded-For: 80.233.xx.xx
Request: [100.93.57.14:48612 (WAN)] GET /updater/status (13 live) #15a93 TLS GZIP Signed-in Token (Mikicv) (iPhone) / accept => text/xml,application/xml / accept-encoding => gzip, deflate, br / accept-language => en-US;q=1, hr-IE;q=0.9 / baggage => sentry-environment=production,sentry-public_key=0f169be102bf41cdbdf13cc3e8902b91,sentry-release=com.plexapp.plex%408.43%2B9570,sentry-trace_id=342a9d7eea4049dfb9a7cc8f883df2bd / Connection => close / Host => plex.domain.com / sentry-trace => 342a9d7eea4049dfb9a7cc8f883df2bd-a9448832451d4965-0 / user-agent => PlexMobile/8.43 (iPhone; iOS 18.1.1; Scale/3.00) / X-Forwarded-For => 80.233.xx.xx / X-Forwarded-Host => plex.domain.com / X-Forwarded-Proto => https / x-plex-client-identifier => 7FBA2717-7129-45D6-AEA7-2A41049B9658 / x-plex-device => iPhone / X-Plex-Device-Name => iPhone / x-plex-device-screen-density => 3 / x-plex-device-screen-resolution => 1290x2796 / x-plex-device-vendor => Apple / x-plex-drm => fairplay:video / x-plex-features => external-media,hub-style-list / x-plex-http-pipeline => infinite / X-Plex-Language => en-IE / x-plex-model => 15,3 / x-plex-platform => iOS / x-plex-platform-version => 18.1.1 / x-plex-playback-id => 684FE1BF-E27A-4D14-898F-9E27461F97FA / x-plex-playback-session-id => 23B97980-2AFC-4150-B51B-A5925B105333 / x-plex-product => Plex for iOS / x-plex-provides => client,controller,sync-target / x-plex-session-id => C644A5C4-732C-4035-8D32-530E3DDF3E9F / x-plex-supported-commands => abort,changeQuality / x-plex-sync-version => 2 / x-plex-token => xxxxxxxxxxxxxxxxxxxx / x-plex-username => Mikicv / x-plex-version => 8.43 / X-Real-IP => 80.233.xx.xx
