Plex + Traefik = not showing real IP address
Server Version#: 1.41.8.9834
I am pulling my hair out trying to solve this issue and would appreciate any help or guidance. I was previously using Nginx Proxy Manager as my reverse proxy and was able to get this working (not sure what I did differently) but now I am on Traefik and can’t figure out how to get the real client IP address to show in Plex dashboard. But for some odd reason, my Apple TVs show up correctly.
Here is a screenshot:
My current setup:
  • Plex’s remote access disabled
  • Plex’s LAN networks field: 10.14.1.0/24,172.14.1.0/24
  • Traefik handling domain certificates
  • Traefik labels:
- "traefik.enable=true"
- "traefik.docker.network=proxy"
- "traefik.http.services.plex.loadbalancer.server.port=32400"
- "traefik.http.services.plex.loadbalancer.serversTransport=default@internal"
- "traefik.http.services.plex.loadbalancer.server.scheme=https"
- "traefik.http.routers.plex-external-secure.service=plex"
- "traefik.http.routers.plex-external-secure.entrypoints=websecure-external"
- "traefik.http.routers.plex-external-secure.rule=Host(plex.${DOMAIN_NAME})"
- "traefik.http.routers.plex-external-secure.tls=true"
- "traefik.http.routers.plex-external-secure.middlewares=websecure-external-middlewares@file"
  • Already have forwardedHeaders set to insecure to allow all headers to pass through while I try to debug this.
  websecure-internal:
    address: ":443"
    forwardedHeaders:
      insecure: true
I dug a little deeper. In my compose file I still had the port 32400 binded:
    ports:
      - 32400:32400/tcp
Which is why I am assuming my Apple TVs were able to bypass Traefik somehow… once I remove the port binds, the Apple TVs showed as 172.14.1.2 as well.
Then I enabled access logs in Traefik and found something interesting. I see Matrix Synapse sending the request_X-Forwarded-For header (with correct IP address). But for Plex it sends request_X-Real-Ip instead (with correct IP address)… not sure what to make of it, any thoughts anyone?
I did manage to make some progress… I found this error in the Plex logs:
ERROR - Illegal allowlist entry covers multiple WAN IPs
That led me to discover that my docker network subnet 172.14.1.0/24 was outside the supported Private Ranges (RFC 1918) which are:
  • 10.0.0.0/8 – covers 10.x.x.x
  • 172.16.0.0/12 – covers 172.16.x.x to 172.31.x.x
  • 192.168.0.0/16 – covers 192.168.x.x
After moving my docker network to 10.255.0.0/24 I am finally able to see WAN IP addresses, both IPv6 and IPv4. That was a crazy thing to learn…
And for the crazy bit, I am now able to see the IP addresses of my devices connected via Unraid’s WireGuard plugin (subnet: 10.14.254.0/24) but when I use Ubiquiti’s WireGuard (subnet 10.14.255.0/24) on my Cloud Fiber Gateway, it doesn’t work.
Now for the bad news: devices on my LAN still don’t show the correct IP address.
