OK, I did further test and created a separate library for tv shows (test) just to start fresh.
The metadata and tv show poster/backdrop works fine. (maybe wasn't working with existing section because I would have to recreate it since it was created originally using TVDB agent...)
Only thing that doesn't work now is the season posters. (and I tested several times different ways)
It should get the "seasonxx-poster.jpg" directly from the tv show folder but it doesn't at all.
Following you over here from the Media Browser forums. I'm having the same issue. The plugin will load image information from season1 but not from season01
So, no you did not lose the Devs, and no the Plugin isn´t dead. There are several, from each other independent
Developers who develop this plugin in their freetime, but they all have other Jobs and other Projects.
In case i have some spare time i will fix it and send a push to Guillaume. Or you may try it fixing by yourself. Simple
Python isnt that difficult
well, for the question "which plugin", see my github link in previous post (didn't know there were more than one....)
This is one of those awkward situations where I can't complain because it's free, not official and third party dev is doing this on his free time...
I personally think Plex should make this agent official and accept the fact that users may have XBMC metadata and images already in place. But that won't happen.
I'm patient and understand that devs sometimes don't have a lot of free time but those Frodo naming conventions have been there for a while now and it's not like XBMC changes their standards every month...
This kind of agent needs to be dependable and up to date as users, when using it, depend on it; it's a core function, it manages the entire library metadata and images in Plex...
So I switched to TVDB agent for my TV shows and download everything in double (since Metabrowser is already handling it already). Just because of this season poster issue...
This is why I mentioned this was an awkward situation; I don't want to disrespect anyone or complain but the fact is that if I would keep this agent and wait for a fix, my TV show structure would be screw up so I changed the agent and rescan EVERYTHING using the official TVDB agent...
Anyways, I think I did the maximum I could by reporting it in details here and adding a Github issue.
Again, I mean no disrespect or bad pressure, I'm just a regular user trying to setup his PMS the best way possible based on what is available.
If I could, I would work on it (I was able to change back myself using the full plot instead of outline in NFO importer for movies) but I don't have the experience or knowledge to fix this one since it's a little more complicated.
Thank you very much for your detailed report. No offense taken. I fully understand the itching feeling one gets when the collection is in inperfect state. :) I promise to have a look at it. Sadly I'm still very busy with work and personal life, so it will take time. I'll have a look at the movie agent first. TV agent is second in line. Please check back here from time to time.
To help me finding the problem could you please create a new folder and copy two seasons of a series to it, that doesn't get recognized correctly? Naming should be exactly as you normally have. Create a section for that folder and zip the logfiles the xbmc tv agent creates and attach them to a new post for me. Thanks. :)
@sfnetwork:
A last question. You enabled the local media assets, okay. Did you drag them above the xbmc agents? The sequence needs to be local media first, then xbmc agent. In case you already have it that way. What does "this will cause the season poster to be mixed up" mean? There are still no season posters showing? Or the wrong ones are?
Also I notice you have folder.jpg files in the seasons folder. While this is okay and they are found by the agent there is an permission denied error shown. Please make sure you have the right permissions and user credentials for all files in your media folder.
Pretty simple, I don't enable local media asset at all because it just uses any poster for the TV show (so if there are folder.jpg in seasons, it sometimes uses a season poster for the main TV show...
I think it should work without Local media asset. Then if it's the case, it can be added first since nfo importer would correct this behaviour.
I shouldn't have folder.jpg at all, I was just trying to test the behaviour.
only have poster.jpg for main TV show and seasonXX-poster.jpg for season.
@sfnetwork: Fix for the season images should be rather trivial. The problem was introduced by outcommenting some code that was in the agent. It was done by another user in good intentions, but as with the multipart movie agent extension sideeffects do show now. Guillaume already reverted part of it, but he left in some things that are creating the problems now.
A question regarding dateadded vs. release date. For what kind of movies do you need this? At the moment if the release date field can not be parsed the fallback is to take the year of the movie and create the date as year-1-1. While not exact IMHO this makes more sense than using dateadded. So what do we do now. Dateadded could be made another fallback, if no year is available. Or if you prefer this, an user changeable option could be added, to use dateadded if no release date is recognized.
Ok, I'm confused now... why are you talking about movies?
This is about TV nfo importer and season posters... Or Am I misunderstanding (sorry if it's the case...)
About movies release date vs date added, now it does what it should but I imagine it could be nice if there is no release dat in nfo, it could fallback on date added. I don't see the need for an option for that personally...
:) Okay. The confusion was on my side. :) I thought somehow, you were talking about dateadded for the movie agent. I'll see that on the weekend a movie agent with last resort fallback to dateadded and and a tvshow agent with fixed season art and dateadded fallback gets released.
Regarding the plexthememusic agent I have sad news. I tried to add it to the agent in putting it in the accepts_from = section. Sadly it gets not picked up by plex. I'm at a loss for now, what I could do otherwise to enable the agent. Propably the plexthememusic agent would need to be modified, too. I somewhat doubt plex will do that.
