Xbox One X buffering and transcoding AAC to AAC?
I’m trying to stream a 4K movie from QNAP to an Xbox One X.
I’ve tried to make life easier for the xbox player so i’ve reached a point where video is direct streaming (not sure what the requirement for direct playing on xbox are), and Audio is transcoding from AAC to AAC.
Video is buffering or shows "playback error - An error occured trying to play “Deadpool”. shaka2017 (Media). if i click Retry it’ll continue playing and buffer some more…
Anyone know what i’m missing?
Media info:
General
Complete name : Deadpool.2016.2160p.x265_aac.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/mp41)
File size : 19.0 GiB
Duration : 1 h 48 min
Overall bit rate : 25.0 Mb/s
Encoded date : UTC 1904-01-01 00:00:00
Tagged date : UTC 1904-01-01 00:00:00
Writing application : Lavf57.83.100
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main@L5@Main
Codec ID : hvc1
Codec ID/Info : High Efficiency Video Coding
Duration : 1 h 47 min
Bit rate : 24.8 Mb/s
Width : 3 840 pixels
Height : 1 608 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Variable
Frame rate : 23.976 (23976/1000) FPS
Minimum frame rate : 1.103 FPS
Maximum frame rate : 24.390 FPS
Original frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.168
Stream size : 18.6 GiB (98%)
Writing library : x265 1.9:[Windows][GCC 4.9.0][64 bit] 8bit
Encoding settings : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=240 / min-keyint=24 / scenecut=40 / rc-lookahead=20 / lookahead-slices=8 / bframes=4 / bframe-bias=0 / b-adapt=2 / ref=3 / limit-refs=3 / no-limit-modes / weightp / no-weightb / aq-mode=1 / qg-size=32 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=3 / psy-rd=2.00 / rdoq-level=0 / psy-rdoq=0.00 / signhide / deblock / sao / no-sao-non-deblock / b-pyramid / cutree / no-intra-refresh / rc=abr / bitrate=25000 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / ipratio=1.40 / pbratio=1.30
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Menus : 3
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Bit rate mode : Constant
Bit rate : 470 kb/s
Channel(s) : 2 channels
Channel(s)_Original : 8 channels
Channel positions : Front: L C R, Side: L R, Back: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 spf)
Compression mode : Lossy
Stream size : 363 MiB (2%)
Title : English DTS-HD NIMA4K
Language : English
Default : Yes
Alternate group : 1
Menus : 3
Menu #1
Codec ID : text
Language : English
Bit rate mode : CBR
Menu For : 1,2
00:00:00.000 : 00:00:00.000
00:03:04.710 : 00:03:04.726
00:05:53.003 : 00:05:53.019
00:09:30.804 : 00:09:30.820
00:13:19.074 : 00:13:19.090
00:16:48.700 : 00:16:48.716
00:20:12.529 : 00:20:12.545
00:22:06.392 : 00:22:06.408
00:27:09.612 : 00:27:09.628
00:31:58.943 : 00:31:58.959
00:36:51.693 : 00:36:51.709
00:41:06.156 : 00:41:06.172
00:44:45.750 : 00:44:45.766
00:46:56.589 : 00:46:56.605
00:50:10.950 : 00:50:10.966
00:53:18.012 : 00:53:18.028
00:55:33.022 : 00:55:33.038
00:59:07.737 : 00:59:07.753
01:03:05.224 : 01:03:05.240
01:07:06.423 : 01:07:06.439
01:09:15.552 : 01:09:15.568
01:12:29.704 : 01:12:29.720
01:16:46.377 : 01:16:46.393
01:20:43.698 : 01:20:43.714
01:25:54.177 : 01:25:53.398
01:31:04.571 : 01:31:03.792
01:34:47.752 : 01:34:46.973
01:39:53.516 : 01:39:52.737
Menu #2
General
Complete name : Deadpool.2016.2160p.x265_aac.srt
Format : SubRip
File size : 99.8 KiB
Text
Format : SubRip
Compression mode : Lossless
Just a note, on my Samsung MU9000 (connected via Wifi, as opposed to the 1Gig LAN connection on my Xbox) it Direct streams both Video and Audio without buffering.
