Will check that but I want to get to connecting like I used to do. If not, then I have to go back to cable( I don’t want to do that). I will look into that. But you have regular connection, correct. That is how I took your post
I do have secure connections from external user and I do have the green check mark indicating that my plex is available externally.
I don’t recall how long it took for everything to be back to “normal” after entering all of my Static IP info.
Maybe try rebooting your plex server machine? If that doesn’t work, give it a day to see if all resolves itself
Finally got it working. Don’t know if it was time or a mistake I may have made.
I checked port forwarding again. Noticed a 0 on end of last number.
example showed 192-168-1-20. That 0 at end of 2 may have been it.
Thanks all for all the help
Bantoot, that’s fantastic news. Congrats!
Yes, that incorrect IP would definitely cause an issue. Who knows what the exact problem was, most importantly you have it resolved.
Enjoy!
