XMLTV for Romania
Server Version#: Latest
Player Version#: Latest
Tuner Make/Model: HD Homerun HDHR5-4DT-R
Guide/Lineup name: DIGI
Using XMLTV?: NO
Channel number/Name: ALL
Still looking for an XMLTV link for Romania. Is there any alternative to get guide data for Digi Romania?
I could not find such an XML online. Due to this I bought a VBOX device, which is a network TV tuner, which provides the XML by itself, taken from the EPG data.
BR,
Mihail
Thank you for your reply, Mihail. Does this vbox plug into the HD homerun? what is the setup process like? where could I find a similar vbox device? Thanks again for the reply
The Vbox is an equivalent of the hdhomerun box, and it is compiling it’s own XML. It connects to the local LAN, and has 4 tv tuners. Plex server finds it automatically, when starting the add DVR setup, and at the xml step, you simply use the url that you find in the vbox device web gui, at the IPTV settings page.
P.S.: I recently took out from the antique drawer and old usb dvb-c tv tuner, which I could add in Plex, while using the same xml URL from the VBOX device, which means you can add the hdhomerun also. So if your hdhomerun has 4 tuners, then you get the vbox with 4 tuners, you will have 8 tuners :slight_smile: Vbox is able to stream the same channel ( or another channel from the same transponder ) to multiple users using only one of the tuners, so in theory it can stream to more than 4 clients.
BR,
Mihail
