The HDHomerun.
However, you must be sure whether you have terrestrial or cable and then select the appropriate HDHomerun model. Your link points to the “cable” model.
If I have cable
But I have seen that online I can share with the rest of the televisions that I have at home. That as they are connected to the Internet and have Plex it is not foolish to put antenna cable to them but to connect them through Plex
