xTeVe - IPTV for Plex DVR
I’m getting errors that plex does not support m3u8 streams. Is this true?
This is not an error, just a warning. Plex expects a .ts stream and no m3u8
Is there any way to install it on a Plex server running on unraid ?
Thank,
Yes, there are several Docker images. Do you find everything in the Discord channel #faq
I’m talking about xTeve and not Plex…
or are you sure ?
I am the developer of xTeVe. A search in the Unraid forum and you will find the xTeVe template :wink:
I see your message, but how install it ?
I believe in the Unraid forum you can be better helped.
[marmei] How do i show a channel (like 24/7 Seinfeld) if it’s not in the EPG guide, like I get from DirectTv? There’s no dummy channel in that guide
Are the channels in the mapping menu visible?
The channels from xTeVe are visible on the left-hand side, but when trying to map to something on the right hand from the EPG guide, there’s no dummy channel there. any solution for that?
I’m super impressed with what you’ve created here.
My question, on my 24/7 channels I get “Client has terminated the connection”. I use the xteve dummy since I’m not seeing a match in the XML. I assume this is where the problem probably lies?
For this you have to use the XEPG function of xTeVe
Thanks. I do use that in settings but then use Directv as my EPG guide in Plex since the channels are clean.
What else should I do to show 24/7 channels that are on in the directv epg?
You need an XMLTV file from your provider, you can then assign the data to the channels and create dummy data.
I have 2 iptv providers, each one supplys about 300 channels, is there a way to run multiple instances of xteve? I’m using a qnap nas
You can do that with Docker, but you can also set up both IPTV providers in xTeVe, if you use Plex, it should not be more than 480 streams. It would not matter to Emby.
Hello all !
I love this application !
Congratulations !!
I have a question, currently i use temporary this application to my windows pc.
But i would like to intall it on debian 9 32 bits.
For the moment i tried all version of this application but no one works.
Can you help ?
For Intel / AMD there is only a 64 bit version
