Unfortunately it doesn’t work. I just have direct files.
I having an issue with recording playback jumpig all over the place, and in some cases just playing the same 20 seconds over and over again. Has anyone else had this issue?
I run all my recorded programmes through tsMuxer. Fixes most problems like you describe.
I run xteve on Mac, how would I auto run
Can someone please let me how I can get xTeve to pick up HD quality streams. I am dealing with an EPG where the names of the channels or the id do not have the word HD in them.
So simply supplying Sports {HD} would end up picking up Zero channels and if I say Sports then the HD quality stream is not picked up, which would otherwise be picked up if I used an app like GSE
What is a solution for this ?
super
sur xteve.de pas de Paypal , car vous mérité pour le merveilleux travail fait !
Great tool, thanks for creating it. If only Plex would have native support for this it would be awesome.
I am however having a problem. I configured xteve and plex with three channels at first. I then changed the playlist in xteve to accommodate six channels. I deleted the DVR from Plex and re-added it. During the configuration in Plex it identifies six channels, it finds the guide for six channels but in the Live TV section I only see three channels, the one I had at first.
Am I doing something incorrectly?
It took some time but all the channels appeared eventually. I guess it’s a set it and forget it scenario.
@marmei - Is there a way to change the order of the channels in the web app? Mine seem to be in a strange order that doesnt match the m3u file or xmltv file?
you can edit the channel number, left click on the channel number
How does xTeVe handle the Plex DVR channel limitations? I use Telly and I have to constantly trim my providers m3u playlist.
480 canal
Hi…
i think I saw a previous post on this from quite a while back, but I can’t seem to work this out.
I had to reboot my machine and now I’m getting the following error:
2019/03/27 16:52:29 [xTeVe] [ERROR] listen udp4 224.0.0.0:1900: bind: address already in use -
I’ve re-installed, and still the same issue.
Any ideas as to how I can resolve this?
thnx.
Hi Guys,
already install on mac.
Following advices of this thread.
Setup an m3u list, that works fine on VLC.
When I try to see live tv, I run into this error
TeVe] [ERROR] EOF - Connection to streaming source was interrupted
do you know what can be?
Your VPN blocks or uses port 1900 itself
Your provider has disconnected the network connection from xTeVe
Is there a way to reset the filters? I just switched providers, and don’t need to filter the list any longer, but I can’t seem to get rid of the last one on the list.
