xTeVe - IPTV for Plex DVR
I tested xTeVe to bring my satellite TV from DVB Viewer into PLEX. This just works fine so far, except that I can only watch one stream at a time. I setup 4 Tuners which all appear within plex and all seems to be fine. But in plex only one client can watch TV, the second shows an error. If I stop the TV stream on the first client, the second can watch without error. I tested 4 Streams parallel direct on the TV-Server where all things run (plex-server, xteve, dvb viewer mediaserver) via DVB viewer and VLC which runs like a charm.
The green dot for the second tuner turns red, too, if I try to start the second stream. That shows that it want to access the second tuner. But it doesn’t work.
Any ideas how to fix that? Thanks!
same here
Bildschirmfoto vom 2022-01-09 16-12-56
only with Browser problem - other clients are streaming…?!?
any ideas?
ad: had the NO transcoderoption activated → Transcoder
everythings fine now
