if there was some way of having the ability to either go into SB/SR through PHT and see like a TV guide of all the shows added to it in like a calendar view so I could see whats on that evening [that I would watch the following day] or see when the next episode of something is on?
I swear there was a similar ability in XBMC back when I used to use it.
just handiness/laziness instead of logging into server and having a look on that. :lol:
I don't use SB anymore (switched to Sonaar) but if I recall you can do this already If you install the SB channel from the unsupported app store.
There is a very cool next on plug-in that fully integrates with XBMC... badly wish someone could port that over as it's really fantastic.
Instead of involving software used for illegal downloading of contents, how about if Plex simply create a calendar system using metadata of the shows within the library? TVDB provides all the information needed already.
to be fair, it was more of a channel request than a feature request. I've posted in the wrong section really.
but I like the TVDB/Plex calendar integration idea! B)
