Server Version#: 1.42.1.10060 ( the only working with HW transcode for me )
Player Version#: (Android) 10.30.6.4151
I`m having issue with media sync.
From Plex Server point of view I have switched ON Library → Settings → 1st checkbox to auto scan library.
There is also auto scan each 12hours set.
Previously ( when I was on Synology ) new files in folders were discovered instantly and library was always up to date. Now on Qnap new files are not discovered. I need to manually scan library from player to refresh it. What can do done/checked to have it auto-scan by server side ?
I recommend running a repair on the Plex database to see if that resolves the issue. I highly recommend using DBRepair—I’ve used it to fix similar problems with great success.
I`m not aware where is the problem.
I can just see that refresh auto and scheduled is not working. System is quite fresh (few days). Library rather small.
Looks like you may have at least a DNS issue Oct 24, 2025 13:05:22.319 [140027781606200] WARN - [HttpClient/HCl#cb2] HTTP error requesting GET https://v4.plex.tv/pms/:/ip (6, Couldn't resolve host name) (Could not resolve host: v4.plex.tv)
On ZFS, each shared folder is UNDERNEATH the ZFSxxx_DATA name.
You have to look inside each one to find the real shared folder name.
( It is a royal “pain in the ******” but that’s how QNAP did it. Other ZFS implementations do it such that the dataset name is the shared folder name )
The app you’re using isn’t compatible. You can’t use it with PMS.
What you need to do. (what many do)
Either:
A: Create (painfully) each library section as it exists without using the app by browsing into the ZFSxxx_DATA directory first.
-OR-
B: (as many do)
Create different folders under Media (which already exists)
Move your media under that folder
EDIT the Plex Library sections to point to the appropriate /share/ZFS18_DATA/xxxxx subfolder
