1.11.0.4666 Commercial Skipping Issues
Since updating to 1.11.0.4666 I have been having issues with commercial skipping for DVR recordings. Was a bug introduced in the new beta version? Is there a solution?
What issues are you referring to?
I’m getting issues with the recording having post processing errors and not removing commercials consistently like it was. I was running 1.11.0.4633 with great results. After upgrading to 1.11.0.4666 I get almost no recordings that have commercials skipped correctly.
yep concur… whatever tweeks they made to comskip it was in the wrong direction
the previous version workd perfectly, now I have it not remvoving all commercials, removing part of the show, ending early and more crashing…
fix it
