1.13 Issues
Hello all,
I have been having all sorts of issues with the 1.13 release. I would like to go back to the most current 1.12 release. Where can I find these?
Thanks,
Steve
since the 1.13 is by now also in the public update channel, you’ll be out of luck (otherwise you could have downloaded from that update channel).
personally I keep the old installers at least until I’ve confirmed the new version is working ok for me.
what issues do you experience?
Its all over the place. I use PMS as a Service and its ending abnormally since 1.13. Last night I was not able to open the Web client on my PMS, telling me a core component has failed. I am about to uninstall and start again with a fresh install but wanted to use 1.12.
Ubuntu or Windows?
I am running it on the latest rev of Windows 10, 1803. I am trying to install 1.13.0.5023 of the PMS.
This should work in a few moments.
https://www.dropbox.com/ *snip
I used that filename to scour my browser history, found official url, appears to work.
https://downloads.plex.tv/plex-media-server/1.12.2.4929-29f6d1796/Plex-Media-Server-1.12.2.4929-29f6d1796.exe
rcombs also posted a 1.12.* in this forum post:
https://forums.plex.tv/discussion/310828/plex-media-server-transcoder-preview-1-12-2-4896/p1
I am thinking of doing the same thing but going to the 12.1.4885 version as that was the last version that did not keep breaking my network card connections such that I have to disable and renable it to get internet working after the recordings having stopped in the middle while surfing the web on the same machine. Does anyone know if I can just execute 4885 and it will do its thing to simply reset to 4885 files or must I unininstall the last public release and reinstall which I hate to do which also means probably reconfiguration and such that I want to avoid too. Regarding versions I also save copies but unless you deleted them they should be found here on your pc in my WIN 7 case… C:\Users\youruserid\AppData\Local\Plex Media Server\Updates
When you uninstall, the configuration and libraries don’t get wiped.
You can reinstall, and everything will be as you left it… I’ve done it several times.
!!However, sometimes databases get tweaked in newer versions that old versions don’t know how to cope with. There is always a risk when downgrading.
I have downgraded my Windows version back to 1709 and will stay there for a bit. Thanks for the download. That got me going again!
