Server Version#: 1.17.0.1709
Player Version#: 4.8.1
Pretty straightforward. Hardware transcoding worked perfectly until the upgrade to the latest version. This needs to be resolved asap. Running the latest windows version and latest nvidia driver. Transcoding works perfectly still in all other apps. Issue is exclusive with Plex.
It also does not failback gracefully to software transcoding. Simply breaks until I uncheck hardware transcoding and then everything works fine.
I noticed hardware transcoding issues as well. Mine is specifically with nvidia decoding MPEG4 video content. Everything else seems to work as intended.
Other users have reported getting their system working by finding the proper method of updating or reinstalling their GPU drivers for their windows version and hardware combination. What Plex might be doing is exercising broken aspects of your install that have not been touched before. And those would be malfunctioning due to Windows’ poor install and update system. Good luck!
Well 436.48 has references to Video Code SDK 9.1 here:
They appeared in 436.30 here also that didn’t work:
I don’t recall having this issue prior to then, not sure if your debian system lines up.
Or if back then I also had an older version of the server installed as the changelog also references quite a few changes to the transcode as well.
I’m using a GTX 970 and an older driver version from what I recall. My issue only seems to be with decoding mpeg4 content, and prior to a recent version of PMS nvdec wasn’t natively supported so I used a workaround which specifically excluded mpeg4 from decoding.
Is your issue with all video files or are there certain formats that still work?
I should have said at the start, rigorous analysis takes a sample, logs, and steps to reproduce.
We’re not there yet, but I feel the pain.
So in the meantime, MPEG-4 covers a broad range of possible encodes.
Your local media is unique. If you get demos from the Kodi archive
or jell.yfish.us that demonstrate the issue, that’s even better.
One topic per person per issue is also reasonable.
