Server Version#: 1.19.3.2852
Upgraded server manually. Now when I start plexmediaserver on ubuntu, it crashes. When I try to access the web server from firefox it tells me the server is unreachable.
Dump file is attached
68e1c899-62ae-042b-622b5560-73658a1b.zip (73.6 KB) .
When I check the status of the service, this is the output:
ubuntu@ubuntu-virtual-machine:~$ sudo systemctl status plexmediaserver.service
● plexmediaserver.service - Plex Media Server
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
Active: deactivating (stop-sigterm) (Result: signal) since Thu 2020-05-28 15:45:31 EDT; 7s ago
Process: 6005 ExecStart=/bin/sh -c export PLEX_MEDIA_SERVER_INFO_VENDOR="$(grep ^NAME= /etc/os-release | awk -F= “{print $2}” | tr -d " )
Process: 6002 ExecStartPre=/bin/sh -c /usr/bin/test -d "{PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "{PLEX_MEDIA_SERVER_
Main PID: 6005 (code=killed, signal=SEGV)
CGroup: /system.slice/plexmediaserver.service
├─6036 Plex Plug-in [com.plexapp.system] /usr/lib/plexmediaserver/Resources/Plug-ins-219a9974e/Framework.bundle/Contents/Resources/
├─6083 /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Resour
├─6085 /usr/lib/plexmediaserver/Plex DLNA Server
├─6120 Plex Plug-in [com.plexapp.agents.movieposterdb] /usr/lib/plexmediaserver/Resources/Plug-ins-219a9974e/Framework.bundle/Conte
├─6123 Plex Plug-in [com.plexapp.agents.lastfm] /usr/lib/plexmediaserver/Resources/Plug-ins-219a9974e/Framework.bundle/Contents/Res
├─6124 Plex Plug-in [com.plexapp.agents.themoviedb] /usr/lib/plexmediaserver/Resources/Plug-ins-219a9974e/Framework.bundle/Contents
├─6126 /usr/lib/plexmediaserver/CrashUploader --directory=/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cr
└─6234 Plex Plug-in [com.plexapp.agents.imdb] /usr/lib/plexmediaserver/Resources/Plug-ins-219a9974e/Framework.bundle/Contents/Resou
May 28 15:45:26 ubuntu-virtual-machine systemd[1]: Starting Plex Media Server…
May 28 15:45:26 ubuntu-virtual-machine systemd[1]: Started Plex Media Server.
May 28 15:45:31 ubuntu-virtual-machine Plex Media Server[6005]: ****** PLEX MEDIA SERVER CRASHED, CRASH REPORT WRITTEN: /var/lib/plexmediaserv
May 28 15:45:31 ubuntu-virtual-machine systemd[1]: plexmediaserver.service: Main process exited, code=killed, status=11/SEGV
