Plexmediaserver 1.19.3.2852.218a8874e_amd64.deb constantly crashed
Server Version#: 1.19.3.2852.218a8874e
I was running pms 1.16 and tried to upgrade to 1.19 yesterday. After successfully downloading and installing the new version, plex refused to start. This is what the system log says:
May 26 09:43:35 ******* systemd[1]: Starting Plex Media Server…
May 26 09:43:35 ******* systemd[1]: Started Plex Media Server.
May 26 09:43:40 ******* Plex Media Server[32207]: ****** PLEX MEDIA SERVER CRASHED, CRASH REPORT WRITTEN: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Crash Reports/1.19.3.2852-219a9974e/PLEX MEDIA SERVER/4f31abc9-7bce-431c-669f4df9-2946cf62.dmp
May 26 09:43:40 ******* kernel: [38734.806667] Plex Media Serv[32222]: segfault at 0 ip 0000000001073437 sp 00007f063e6d76b0 error 4 in Plex Media Server[961000+dca000]
May 26 09:43:40 ******* kernel: [38734.806682] Code: 74 05 e8 0c 2b 6b 00 48 8b 7c 24 08 4c 39 ef 74 05 e8 fd 2a 6b 00 84 db 0f 85 a5 00 00 00 48 8b 44 24 50 48 8b b0 30 02 00 00 <48> 8b 06 48 8d bc 24 a8 00 00 00 48 8b 94 24 98 00 00 00 48 8d 8c
May 26 09:43:40 ******* systemd[1]: plexmediaserver.service: Main process exited, code=killed, status=11/SEGV
May 26 09:43:43 ******* Plex Media Server[32207]: Error starting framework core for /usr/lib/plexmediaserver/Resources/Plug-ins-219a9974e/PlexMovie.bundle.
May 26 09:45:10 ******* systemd[1]: plexmediaserver.service: State ‘stop-sigterm’ timed out. Killing.
May 26 09:45:10 ******* systemd[1]: plexmediaserver.service: Killing process 32233 (Plex Script Hos) with signal SIGKILL.
May 26 09:45:10 ******* systemd[1]: plexmediaserver.service: Killing process 32287 (Plex Tuner Serv) with signal SIGKILL.
May 26 09:45:10 ******* systemd[1]: plexmediaserver.service: Killing process 32320 (Plex Script Hos) with signal SIGKILL.
May 26 09:45:10 ******* systemd[1]: plexmediaserver.service: Failed with result ‘signal’.
May 26 09:45:16 ******* systemd[1]: plexmediaserver.service: Service RestartSec=5s expired, scheduling restart.
May 26 09:45:16 ******* systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 4.
May 26 09:45:16 ******* systemd[1]: Stopped Plex Media Server.
After spending hours in trying to find out what’s going wrong (including deleting plugins), I tried to revert to pms 1.16. Unexpectedly, this version boots up perfectly and everything is working fine.
Does anyone know what might go wrong here?
I too am having the same issue upgrading from 1.16.0.1226-7eb2c8f6f to 1.19.3.2852-219a9974e. Same issue crash wont restart. But i install the oldest version no issue.
May I have the DEBUG logs ZIP file of whatever you have?
Similar but on a Mac: Version 1.19.3.2852 will not start.
I can’t help with a Mac. I only have Linux machines.
Are there logs available which show a partial start?
